[GRASS-user] Problem with the tcl/tk GUI
Martin Mainzer
martmai at gmx.de
Tue Jun 16 13:01:50 EDT 2009
Hello,
I just installed the grass 6.4.0 RC4 *.rpm from
http://download.opensuse.org/repositories/Application:/Geo/openSUSE_10.3
on my OpenSuse 10.3 machine.
Within the nc dataset I opened the sqlite mapset and copied the the
geology map to the splite mapset with:
~> g.copy vect=geology at PERMANENT,geology
Then I tried to show the attribute table of the geology map by using the
tcl/tk GUI (the button in the lower part of the GIS Manager window). By
clicking the button 'Show attribute data' the following command is sent
to the GIS.m window:
db.select table=geology
database=/home/martin/GISDataBase/nc_spm_08/sqlite/sqlite.db driver=dbf
Note the driver option! This command fails with the error:
Cannot open dbf database:
By correcting the driver option to sqlite everything works fine.
By the way: v.db.connect -p geology shows the correct sqlite driver.
Martin
