[GRASS-user] r.proj..."has stopped working"
Richard Feldman richard.feldman at mail.mcgill.ca
Tue Jun 16 13:24:10 EDT 2009
Hi and thank you for the quick reply.
It still doesn't work. I tried r.proj with my destination location being
the one I've been working with and I tried it with a new location with a
lat/lon wgs84 projection. Both times, "r.proj has stopped working." (I
tried with both elevation.dem and density). I also tried. v.proj with
"streams" and that worked fine.
(Tue Jun 16 11:09:28 2009)
r.proj in=elevation.dem location=spearfish60 mapset=PERMANENT
out=elevation.dem
(Tue Jun 16 11:09:31 2009) Command finished (3 sec)
Any ideas on what's wrong???
Richard Feldman
Hamish wrote:
> Richard wrote:
>> I am trying to project a raster with r.proj. Although it
>> seemed to work fine the other day, today  it's not
>> working. The function stops and in Windows Vista the message
>> "r.proj has stopped working" pops up. I know there may be
>> size limitations but I'm trying to project a raster that's
>> only 7000KB. Has anyone else experienced this (GRASS 6-SVN,
>> Windows Vista)? Is there some other way I can import this
>> raster and have it project properly? Should I try
>> re-installing GRASS?
> Hi, can you reproduce this with one of the standard datasets? (spearfish
> or NC) e.g. when pulling a raster map from them into lat/lon wgs84.
> Hamish
Richard Feldman, PhD Candidate
Dept. of Biological Sciences, McGill University
W3/5 Stewart Biology Building
1205 Docteur Penfield
Montreal, QC H3A 1B1
514-212-3466
