[GRASS-user] v.delaunay Bug in Mac OS X
Michael Perdue
michael_perdue at yahoo.ca
Tue Jun 16 18:50:15 EDT 2009
v.delaunay is generating incorrect results on Mac OS X on my machine
(Intel Mac Pro, Leopard, W. Kyngesburye's GRASS 6.4-RC5 binaries). The
following commands give the results below;
echo "456490.2375|5905949.8625|1
456690.09166667|5905895.5625|2
456570.93333333|5905821.65416667|3
456579.22916667|5905881.9875|4
456494.00833333|5905859.3625|5
456673.5|5905819.39166667|6
456601.85416667|5905782.4375|7
456604.11666667|5905944.58333333|8" | v.in.ascii -n
output=DelaunayPoints cat=3
v.delaunay input=DelaunayPoints output=DelaunayTriangles
Building topology for vector map <DelaunayTriangles>...
Registering primitives...
12 primitives registered
24 vertices registered
Building areas...
100%
4 areas built
1 isles built
Number of nodes: 8
Number of primitives: 12
Number of points: 0
Number of lines: 0
Number of boundaries: 12
Number of centroids: 0
Number of areas: 4
Number of isles: 1
Number of incorrect boundaries: 4
Number of areas without centroid: 4
WARNING: Unable to calculate area centroid z coordinate
100%
Attaching islands...
100%
Attaching centroids...
100%
Number of nodes: 11
Number of primitives: 15
Number of points: 0
Number of lines: 0
Number of centroids: 3
Number of areas: 4
Number of isles: 1
Number of areas without centroid: 1
g.region vect=DelaunayPoints
d.mon x0
d.vect DelaunayTriangles
d.vect map=DelaunayPoints color=red width=0 icon=basic/circle size=10
Name: v.delaunay problem.tiff
Type: image/tiff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090616/f88238bb/v.delaunayproblem-0001.tiff
I've tested it on the same machine running Linux and had no issue. It
also ran without issue on Mac OS X with GRASS 6.3. Can anyone verify
that it isn't working properly anymore or could it be a problem with
my installation?
Cheers,
Mike
