[GRASS-user] Problem exporing rasters
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Tue Jun 16 21:27:01 EDT 2009
Hi Richard,
Send the outputs of the command below to the list:
g.region -p
r.info studyarea
r.info elevation
r.info newelevation
This will help the helpers :-)
Bests,
milton
brazil=toronto
2009/6/16 Richard Feldman <richard.feldman at mail.mcgill.ca>
> Hi,
> I have two rasters. One is an elevation dataset from Worldclim, imported
> into GRASS using r.in.bin. The other is a MODIS raster, which I had
> previously worked on in ArcGIS. Consequently, I imported this raster (.adf)
> into GRASS using r.in.gdal. Both rasters display and manipulate properly in
> GRASS. I used r.mapcalc to mask the raster
> newelevation=if(studyarea at mapset, elevation at mapset)
> and wished to export this new raster as an ascii grid. When using either
> r.out.gdal or r.out.arc, the exported file is only 1KB and does not contain
> any data e.g. elevations). (Again, this new raster displays fine in GRASS).
> With r.out.gdal, I have tried both .grd and .tif formats as well as “byte,”
> “int16,” “uint16” and “int32” file types. Every time the export takes 0 sec
> and produces a 1-2KB file.
> I have tried exporting elevation.dem from the spearfish dataset and it
> exports fine. I'm using GRASS6-SVN on Windows Vista.
> What am I doing wrong?
> Richard Feldman_______________________________________________
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090616/e2dfd6d4/attachment.html
