[GRASS-user] Re: [GRASS-dev] New WinGrass Release (6.4.0RC5)
Hamish hamish_b at yahoo.com
Wed Jun 17 05:30:21 EDT 2009
Martin wrote:
> the last time I ended up in the hell of mixing libraries built using
> mingw (GRASS) and msvs (wxpython). Currently I have no time for this
> kind of "fun". If somebody put on wiki instructions how to overcome
> this problem I will be happy to fix MS Windows related bugs to make
> these extensions working under MS Windows.
have you tried the updated & simplified build instructions using osgeo4w
as the framework?
https://trac.osgeo.org/grass/wiki/CompileOnWindows
then hopefully it is mostly a matter of making sure the PATH order is
correct. (??)
Hamish
