[GRASS-user] can the grass calculate the area of different color for a image(tiff or other?)
maven apache apachemaven0 at gmail.com
Wed Jun 17 08:06:46 EDT 2009
I got a.green a.red a.blue and a.alpha four raster,then follow the advise
from this list I composite the three map g b r to a new raster:outss
then I run the commond r.stats -a input=outss at PERMANENT fs=space nv=*
nsteps=255
got the following output
0 429847.542397
9321 212745757.083273
26425 4430667.032198
31744 5444337463.194785
32736 35683640.857434
32767 92624.052023
I wonder what do the first number in each line respent? And the second
number in each respent the area?
2009/6/17 Micha Silver <micha at arava.co.il>
>  maven apache wrote:
> Yes
> My tiff have 5 color, red blue green and pink and yellow. I want get the
> area for each color..
> First I import the tiff .however I got a.green a.red a.blue and a.alpha
> four raster.
> Multi-band tiffs are imported as separate bands. You can combine them with
> r.composite.
>> maven apache wrote:
>> can the grass calculate the area of different color for a image?
>>> I have a tiff, and I have seen five color in it,I wonder I can calculate
>>> the area for each color with grass?
>> Did you check out r.stats -a ?
>>> This mail was received via Mail-SeCure System.
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090617/d2398e3e/attachment.html
