[GRASS-user] can the grass calculate the area of different color
for a image(tiff or other?)
Micha Silver
micha at arava.co.il
Wed Jun 17 08:55:35 EDT 2009
Moritz Lennert wrote:
> On 17/06/09 14:06, maven apache wrote:
>> I got a.green a.red a.blue and a.alpha four raster,then follow the
>> advise from this list I composite the three map g b r to a new
>> raster:outss
>> then I run the commond r.stats -a input=outss at PERMANENT
>> <mailto:input=outss at PERMANENT> fs=space nv=* nsteps=255
>> got the following output
>> 0 429847.542397
>> 9321 212745757.083273
>> 26425 4430667.032198
>> 31744 5444337463.194785
>> 32736 35683640.857434
>> 32767 92624.052023
>> I wonder what do the first number in each line respent? And the
>> second number in each respent the area?
> RTFM ;-)
> The first number is the category number, i.e. the different categories
> (in your case colors) present in your map.
> The second number gives the area statistics which are given in units
> of square meters.
> Moritz
> ________
And if you want to improve the output, then two steps:
First use r.category to give a label to each category like so:
(assuming the first is black)
echo "0:Black" | r.category outss rules=-
(note the '-' which means "read from stdin")
Next use r.report like so:
r.report outss unit=k
(gives a table with the cat value, the label and area in sqkm)
> _______________________________________
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
