[GRASS-user] v.proj failed
Markus GRASS
markus.metz.giswork at googlemail.com
Thu Jun 18 02:40:29 EDT 2009
Hamish wrote:
> Markus M wrote:
>> If the latlon region crosses the 180E/W border, this is an
>> inherent bug
> note for raster modules -180 to +360 are supported. that way
> both -180 to +180 and 0 to 360 are supported. (platenary
> scientists like to work in 0-360)
> A goal is that vector modules should be lat/lon wrap aware and
> suppot the same (this largely lags behind lat/lon support in
> raster libs/modules).
Hmm, I thought raster cellhd entries are limited to 180E/W, but in
latlon it is allowed that East < West in cellhd. The display can show
lon beyond 180E/W and wraps rasters as necessary.
There are a few problems with latlon wraparound in vectors, i.e. chop
areas in pieces so the boundary coordinates are within 180E/W, what to
do with lines, split them too but then what happens with network
analysis, how to select features by bounding box?
Anyway, I don't think that this was the problem of v.proj that Timmie
observed. There was a problem in the spatial index while splitting
nodes, without the problem vector and a lot of patient debugging it is
impossible to tell why (at least for me knowing just a bit about RTree
node splitting methods). There is probably an easy fix but I'm not sure
if that fix would not introduce a new bug.
Markus M
