[GRASS-user] can the grass calculate the area of different color
for a image(tiff or other?)
maven apache
apachemaven0 at gmail.com
Thu Jun 18 09:26:24 EDT 2009
Thanks I have tried it ,and I found each transfered vector map is
not compatible with the real color position of the image......
2009/6/18 Moritz Lennert <mlennert at club.worldonline.be>
> > <mailto:mlennert at club.worldonline.be>>
> > On 18/06/09 14:31, maven apache wrote:
> > > Also I found that I can see only five color from the tiff
> > > swi.tiff, and yesterday I get five category with the same
> > > steps(import and composite then calculate ), they are
> > > "0
> > > 9321 26425 31744 32736 ";, but today it change to six!!
> > > Maybe I remembered it wrongly. (*^__^*)
> > > And acturlly I want to extract each color and export them
> > to a
> > > vector map, I am looking the proper commond.
> > > It seems that there is no corresponding command to achieve this
> > goal£¿
> > Please start by reading:
> > http://grass.osgeo.org/grass64/manuals/html64_user/rasterintro.html
> > http://grass.osgeo.org/grass64/manuals/html64_user/vectorintro.html
> > The command you are looking for is r.to.vect (I see it is not
> mentioned
> > in the rasterintro. Should be...).
> > It seems that the r.to.vect is to transfer the hole raster map to a
> > vector,but I want to transfer each category to a vector....
> The easiest solution is probably a combination of r.to.vect + v.extract.
> Moritz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090618/5f5e4abd/attachment.html
