[GRASS-user] v.out.ogr to KML ERROR 1: Latitude is invalide
maven apache apachemaven0 at gmail.com
Thu Jun 18 22:40:20 EDT 2009
This is a vector layer transfered from a raster and its general info can be
seen as follows:
 | Layer:           swi_0 at PERMANENT
 | Mapset:          PERMANENT
 | Database:        D:/GrassDataBase
 | Title:
 | Map scale:       1:1
 | Map format:      native
 | Name of creator: Administrator
 | Organization:
 | Source date:     Thu Jun 18 20:51:48 2009
 |   Type of Map:  vector (level: 2)
 |   Number of points:       0               Number of areas:      88
 |   Number of lines:        0               Number of islands:    79
 |   Number of boundaries:   229             Number of faces:      0
 |   Number of centroids:    84              Number of kernels:    0
 |   Map is 3D:              0
 |   Number of dblinks:      1
 |         Projection: Universe Transverse Mercator (zone 0)
 |               N:  2762370.84493965    S:  2668889.78644383
 |               E:   636604.74247833    W:   592287.35339113
 |   Digitization threshold: 0
 |   Comments:
then I want to export it to kml and add it to the google earth, I use the
commond:
g.region vect=swi_blue at PERMANENT
v.out.ogr input=swi_blue at PERMANENT type=area dsn=d:/blueNew.kml layer=1
format=KML
and I got the errors:
arning 1: Layer name 'swi_blue at PERMANENT' adjusted to 'swi_blue_PERMANENT'
for XML validity.
Exporting 4893 areas (may take some time) ...
ERROR 1: Latitude 2764980.037140 is invalid. Valid range is [-90,90]. This
warning will not be issued any more
Warning 1: Longitude 638073.992861 has been modified to fit into range
[-180,180]. This warning will not be issued any more
9259 features written
4476 features without category written
it seems that there is something wrong with the Coordinate,but  Latitude
2764980.037140 is the same with the general info from the command
v.infomap=''''''.
I wonder it is my problem or the grass?
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090619/4faa1346/attachment-0001.html
