[GRASS-user] v.out.ogr to KML ERROR 1: Latitude is invalide
Moritz Lennert
mlennert at club.worldonline.be
Fri Jun 19 03:39:06 EDT 2009
On 19/06/09 09:27, Moritz Lennert wrote:
> On 19/06/09 04:40, maven apache wrote:
>> This is a vector layer transfered from a raster and its general info
>> can be seen as follows:
>> | Layer:
>> swi_0 at PERMANENT |
>> Mapset: PERMANENT
>> | Location:
>> newlocation |
>> Database: D:/GrassDataBase
>> Title:
>> | Map scale:
>> 1:1 | Map
>> format: native
>> | Name of creator:
>> Administrator |
>> Organization:
>> | Source date: Thu Jun 18 20:51:48
>> 2009
>> | Type of Map: vector (level:
>> 2)
>> | Number of points: 0 Number of
>> areas: 88 | Number of lines: 0
>> Number of islands: 79 | Number of boundaries:
>> 229 Number of faces: 0 | Number of
>> centroids: 84 Number of kernels: 0
>> | Map is 3D:
>> 0 | Number of
>> dblinks: 1
>> | Projection: Universe Transverse Mercator (zone
>> 0) | N: 2762370.84493965 S:
>> 2668889.78644383 | E:
>> 636604.74247833 W: 592287.35339113
>> | Digitization threshold:
>> 0 |
>> Comments:
>> then I want to export it to kml and add it to the google earth, I use
>> the commond:
>> g.region vect=swi_blue at PERMANENT v.out.ogr input=swi_blue at PERMANENT
>> type=area dsn=d:/blueNew.kml layer=1 format=KML
>> and I got the errors:
>> arning 1: Layer name 'swi_blue at PERMANENT' adjusted to
>> 'swi_blue_PERMANENT' for XML validity.
>> Exporting 4893 areas (may take some time) ...
>> ERROR 1: Latitude 2764980.037140 is invalid. Valid range is [-90,90].
>> This warning will not be issued any more
>> Warning 1: Longitude 638073.992861 has been modified to fit into range
>> [-180,180]. This warning will not be issued any more
>> 9259 features written
>> 4476 features without category written
>> it seems that there is something wrong with the Coordinate,but
>> Latitude 2764980.037140 is the same with the general info from the
>> command v.info <http://v.info> map=''''''.
>> I wonder it is my problem or the grass?
> On the KML page of OGR it says: "Note that KML by specification uses
> only a single projection, EPSG:4326" [1]
> It also says "As such OGR will create layers in the correct coordinate
> system and transform any geometries."
> Not sure how to interpret this, but from your error message, I would
> guess that you have to reproject your vector to a epsg:4326 location
> first, before exporting with v.out.ogr.
> Moritz
> [1]http://www.gdal.org/ogr/drv_kml.html
Sorry, just reread your message, and my answer is probably not really
helpful. In fact v.out.ogr does transform your data to EPSG 4326, as the
following message shows:
No, idea what the ERROR means. What does the resulting KML file look like ?
You still might want to try to reproject (v.proj) to EPSG 4326, just to
see what happens.
Moritz
