[GRASS-user] Errors in nviz when I tried to compiled GRASS_RC5
an RC4
Jhon Ortiz
eljhonjhon at hotmail.com
Fri Jun 19 12:20:05 EDT 2009
> Hi,
> 2009/6/19 Jhon Ortiz <eljhonjhon at hotmail.com>:
> > /usr/local/src/grass-6.4.0RC5/lib/nviz
> > /usr/local/src/grass-6.4.0RC5/gui/wxpython/nviz
> > /usr/local/src/grass-6.4.0RC5/visualization/nviz
> > /usr/local/src/grass-6.4.0RC5/visualization/nviz2/cmd
> > I'm not a expert linux user. Some advice about which is my mistake? and I
> > tried with GRASS_RC4
> > and had the same errors!!
> go to lib/nviz, run make and post there error log. Without log it's
> quite impossible to say what is wrong.
> Martin
This is the log,
john at cito:/usr/local/src/grass-6.4.0RC4/lib/nviz$ make
mkdir -p /usr/local/src/grass-6.4.0RC4/bin.
mkdir -p /usr/local/src/grass-6.4.0RC4/dist./include/grass
mkdir -p /usr/local/src/grass-6.4.0RC4/dist./lib
mkdir -p /usr/local/src/grass-6.4.0RC4/dist./bin
mkdir -p /usr/local/src/grass-6.4.0RC4/dist./etc
mkdir -p /usr/local/src/grass-6.4.0RC4/dist./driver
mkdir -p /usr/local/src/grass-6.4.0RC4/dist./driver/db
mkdir -p /usr/local/src/grass-6.4.0RC4/dist./fonts
test -d OBJ. || mkdir -p OBJ.
gcc -I/usr/local/src/grass-6.4.0RC4/dist./include -g -Wall -fPIC -DPACKAGE=\""grasslibs"\" -I/usr/include/gdal -DPACKAGE=\""grasslibs"\" -I/usr/local/src/grass-6.4.0RC4/dist./include -o OBJ./change_view.o -c change_view.c
change_view.c:19:27: error: grass/glocale.h: No such file or directory
change_view.c:20:24: error: grass/nviz.h: No such file or directory
change_view.c: In function ‘Nviz_resize_window’:
change_view.c:43: warning: implicit declaration of function ‘GS_set_viewport’
change_view.c:46: warning: implicit declaration of function ‘GS_set_draw’
change_view.c:46: error: ‘GSD_BACK’ undeclared (first use in this function)
change_view.c:46: error: (Each undeclared identifier is reported only once
change_view.c:46: error: for each function it appears in.)
change_view.c:47: warning: implicit declaration of function ‘GS_ready_draw’
change_view.c:48: warning: implicit declaration of function ‘GS_alldraw_wire’
change_view.c:49: warning: implicit declaration of function ‘GS_done_draw’
change_view.c: At top level:
change_view.c:61: error: expected ‘)’ before ‘*’ token
change_view.c:97: error: expected ‘)’ before ‘*’ token
change_view.c:138: error: expected ‘)’ before ‘*’ token
change_view.c:168: error: expected ‘)’ before ‘*’ token
change_view.c:188: error: expected ‘)’ before ‘*’ token
change_view.c:205: error: expected ‘)’ before ‘*’ token
make: *** [OBJ./change_view.o] Error 1
John
_________________________________________________________________
Llévate Messenger en el móvil a todas partes ¡Conéctate!
http://www.microsoft.com/spain/windowsmobile/messenger/default.mspx
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090619/ee1c89c5/attachment.html
