[GRASS-user] g.mapset unable to read GIS_LOCK env variable
    Daniel Victoria
    daniel.victoria at gmail.com
    Fri Jun 19 15:32:28 EDT 2009
Hi all,
Using Grass 6.4.0 from Osgeo4W in WinXP. When I try to change my
mapset inside a grass section by typing, for example,  g.mapset
PERMANENT at the prompt I get the error:
GRASS 6.4.0svn (utm23)> g.mapset PERMANENT
ERROR: Unable to read GIS_LOCK environment variable
I get the same if I try to change the mapset using the wxgui. A WinXP
problem I guess?
Cheers
Daniel
