[GRASS-user] problem creating point layer from CSV file
John A Stevenson john.stevenson at manchester.ac.uk
Tue Jun 23 08:41:56 EDT 2009
To set the column type in db.in.ogr for a csv file, you have to create
another file (e.g. points_in.csvt) with the column types.
See:
g.manual db.in.ogr
or
http://www.gdal.org/ogr/drv_csv.html
Alternatively, load the csv file with v.in.ascii, which will give you a
chance to describe the column types.
Later
John
Tim Michelsen wrote:
> Hello,
> I tried to create a point vector from a table with coordinates:
> db.in.ogr dsn=points_in.csv output=points key=myid
> v.in.db --overwrite table=points x=UTM_E y=UTM_N key=myid
> output=points_vect
> => ERROR: x/y/z column must be integer or double
> Why do I get this error?
> How to I change the table column format for an imported ascii (CSV)
> table in order to match integer or double?
> Thanks for your help.
> Kind regards,
> Timmie
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
