[GRASS-user] v.out.ogr & kml
Hamish hamish_b at yahoo.com
Tue Jun 23 22:49:08 EDT 2009
maven apache wrote:
> Hi:It seems that I have
> encountered the same problem,actually you should reproject
> your map by yourself if you are using a earlier
> version.In the later version it can reproject
> autoly.
i.e. a bug in GDAL/OGR got fixed so you need a newish version of
that.
you might also try v.out.gpsbabel which attempts to reproject to
WGS84 LL in GRASS. (less than optimal but it seems to work)
Hamish
