[GRASS-user] v.out.ogr to KML ERROR 1: Latitude is invalide
Richard rchirgwin at ozemail.com.au
Wed Jun 24 00:24:06 EDT 2009
> Message: 7
> Date: Fri, 19 Jun 2009 10:40:20 +0800
> From: maven apache <apachemaven0 at gmail.com>
> Subject: [GRASS-user] v.out.ogr to KML ERROR 1: Latitude is invalide
> To: grass-user at lists.osgeo.org
> Message-ID:
> 	<b6ae15040906181940u733d7369tb267be73d167856d at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> This is a vector layer transfered from a raster and its general info can be
> seen as follows:
>  | Layer:           swi_0 at PERMANENT
>  | Mapset:          PERMANENT
>  | Location:        newlocation
>  | Database:        D:/GrassDataBase
>  | Title:
>  | Map scale:       1:1
>  | Map format:      native
>  | Name of creator: Administrator
>  | Organization:
>  | Source date:     Thu Jun 18 20:51:48 2009
>  |   Type of Map:  vector (level: 2)
>  |   Number of points:       0               Number of areas:      88
>  |   Number of lines:        0               Number of islands:    79
>  |   Number of boundaries:   229             Number of faces:      0
>  |   Number of centroids:    84              Number of kernels:    0
>  |   Map is 3D:              0
>  |   Number of dblinks:      1
>  |         Projection: Universe Transverse Mercator (zone 0)
>  |               N:  2762370.84493965    S:  2668889.78644383
>  |               E:   636604.74247833    W:   592287.35339113
>  |   Digitization threshold: 0
>  |   Comments:
> then I want to export it to kml and add it to the google earth, I use the
> commond:
> g.region vect=swi_blue at PERMANENT
> v.out.ogr input=swi_blue at PERMANENT type=area dsn=d:/blueNew.kml layer=1
> format=KML
> and I got the errors:
> arning 1: Layer name 'swi_blue at PERMANENT' adjusted to 'swi_blue_PERMANENT'
> for XML validity.
> Exporting 4893 areas (may take some time) ...
> ERROR 1: Latitude 2764980.037140 is invalid. Valid range is [-90,90]. This
> warning will not be issued any more
> Warning 1: Longitude 638073.992861 has been modified to fit into range
> [-180,180]. This warning will not be issued any more
> 9259 features written
> 4476 features without category written
> it seems that there is something wrong with the Coordinate,but  Latitude
> 2764980.037140 is the same with the general info from the command
> v.infomap=''''''.
> I wonder it is my problem or the grass?]
KML is expecting latitude-longitude formats, but you seem to be in a
projected location.
Try this:
1) Create a new lat-long (in degrees) location with region suitable to
your map.
2) Start Grass in the new location.
3) Use v.proj to transfer the old map into your lat-long location. Eg:
v.proj input=<your map> location=<old location> mapset=PERMANENT
4) Try running v.out.ogr from there.
Richard
