[GRASS-user] Problems with GRASS python code in osgeo4w
Hamish hamish_b at yahoo.com
Wed Jun 24 07:43:37 EDT 2009
Bob Moskovitz:
> I noticed that most of the *.bat files have forward slashes.
>  For example:
> C:\OSGeo4W\apps\grass\bin\grass64.bat:                 set WINGISBASE=/c/OSGeo4W/apps/grass/grass-6.4.0RC4
> C:\OSGeo4W\apps\grass\grass-6.4.0svn\bin\d.correlate.bat:    @"%GRASS_SH%" -c '"%GISBASE%/scripts/d.correlate" %*'
> C:\OSGeo4W\apps\grass\grass-6.4.0svn\etc\Init.bat:        if "%GRASS_PROJSHARE%"=="" set GRASS_PROJSHARE=/c/OSGeo4W/share/proj
> C:\OSGeo4W\bin\grass64.bat                        set WINGISBASE=%OSGEO4W_ROOT%/apps/grass/grass-6.4.0svn
> Why is there 2 grass64.bat?
osgeo4w actually ships with 3: (!)
C:\OSGeo4W\apps\grass\bin\grass64(.sh) and grass64.bat  (unused)
  https://trac.osgeo.org/osgeo4w/ticket/73
  https://trac.osgeo.org/osgeo4w/ticket/90
C:\OSGeo4W\etc\ini\grass.bat  (sets enviro vars like GRASS_WISH)
  https://trac.osgeo.org/osgeo4w/ticket/86
C:\OSGeo4W\bin\grass64.bat  (and grass64.bat.tmpl)
  this is what is used to actually launch grass
Glynn:
> The rest of them are wrong.
> I didn't realise that the problems with OSGeo4W were this bad.
note what he listed above are from an unused script with OSGeo4W.
(but are used in the stand-alone installer)
things seem to work, e.g. the r.out.xyz shell script works
both from the DOS prompt and the wxGui.
> I suggest that you use the standalone GRASS packages rather than
> OSGeo4W.
if nothing else, the OSGeo4W package is rather old now (6.4svn from 4 May '9)
> Or at least report OSGeo4W-specific problems to the OSGeo4W
> list or tracker.
[except for the 3x grass.bat scripts stuff] note that in general
the stand-alone installer is built out of the osgeo4w tree &
vice versa. they're almost the same thing - at least they share
a lot.
e.g. see mswindows/osgeo4w/ in the grass source code for wxNviz
and wxVdigit linking stuff.
see https://trac.osgeo.org/osgeo4w/wiki/pkg-grass#PackagerNotes
 for partial build method.
Hamish
