[GRASS-user] Compiling weekly source; two make errors
William Kyngesburye woklist at kyngchaos.com
Wed Jun 24 20:57:49 EDT 2009
On Jun 24, 2009, at 7:42 PM, Seth Price wrote:
> I'm having two errors while compiling. The first is "no rule to make
> target", so perhaps something wrong with the build system? The
> second is a
> missing include file, which is odd because it's there. I'm not exactly
> sure what to make of it. (see the last few commands in the included
> log)
> Am I doing anything wrong?
> Thanks,
> Seth
> $ ./configure --enable-shared --prefix=/Applications --enable-macosx-
> app
> --with-opengl=aqua --with-freetype-includes=/usr/local/include/
> freetype2
> && make && sudo make install
> gcc
> -I/usr/local/grass/grass-7.0.svn_src_snapshot_2009_06_20/dist.i386-
> apple-darwin9.7.0/include
> -g -O2
>  -I/usr/local/include  -D_FILE_OFFSET_BITS=64  -DPACKAGE=\"\"
> -o OBJ.i386-apple-darwin9.7.0/togl.o -c togl.c
> In file included from togl.c:53:
> /usr/include/tkMacOSX.h:19:19: error: tkInt.h: No such file or
> directory
> In file included from /usr/include/tkMacOSX.h:32,
>                 from togl.c:53:
> /usr/include/tkPlatDecls.h:107: error: syntax error before ‘*’ token
> /usr/include/tkPlatDecls.h:152: error: syntax error before ‘*’ token
> togl.c:54:54: error: tkMacOSXInt.h: No such file or directory
> togl.c:265: error: syntax error before ‘XVisualInfo’
> togl.c:265: warning: no semicolon at end of struct or union
> togl.c:271: error: syntax error before ‘}’ token
> togl.c:310: error: invalid use of incomplete typedef ‘Togl’
> togl.c:313: error: invalid use of incomplete typedef ‘Togl’
The system tcltk was detected by default.  While it is v8.4, it is not
suitable for GRASS (it's an Aqua-fied version, and v8.5 is needed for
that).  You should download and install ActiveTcl 8.5 (I'm not sure if
8.6 will work).  See the macosx readme in the source for more gorey
details on compiling for OSX.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly
what the universe is for and why it is here, it will instantly
disappear and be replaced by something even more bizarrely
inexplicable.  There is another theory which states that this has
already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
