[GRASS-user] Point attributes to a polygons
    xavier garcia acosta
    epistacio at hotmail.com
    Thu Jun 25 07:42:24 EDT 2009
Yes, you have understood my question. I've tried that you have recommended to
my and now I have the next problem, I've tried to do “v.patch”
with the option “copy also attribute table” with my two GRASS
vector maps and I have the error “Number of columns differ”. Do
you know how can I solve this?
Xavier
> Date: Thu, 25 Jun 2009 13:00:35 +0300
> From: micha at arava.co.il
> To: epistacio at hotmail.com
> CC: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] Point attributes to a polygons
> xavier garcia acosta wrote:
> > Hello everybody,
> > I'm working with cadastre information and I've got the next problem.
> > I've the polygons that represent the plots of the houses but without
> > any attribute. I've also the points with the attributes of the
> > previous polygons. That I would like to do is to add the attributes of
> > the points to the polygons. Has anybody got any idea how to do it?
> Are these GRASS vectors? If so, then "polygons" do not have attributes.
> An area feature is made of closed boundary lines and the centroid. The
> boundary lines can belong to several areas, so attributes that are
> attached to the boundary lines do not represent a particular area. The
> centroid, on the other hand, will exactly correspond to the area.
> So, if I understand your question, all you have to do is merge the two
> vectors (v.patch), then convert the points to centroids (v.type) and
> you're done. The points as centroids already hold the attributes.
> > Thanks
> > Nuevo Windows Live, un mundo lleno de posibilidades Descu'brelo.
> > <http://www.microsoft.com/windows/windowslive/default.aspx>
> > This mail was received via Mail-SeCure System.
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
_________________________________________________________________
Chatea sin límites en Messenger con la tarifa plana de Orange
http://serviciosmoviles.es.msn.com/messenger/orange.aspx
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090625/a306e219/attachment.html
