[GRASS-user] Compiling weekly source; two make errors
Thu Jun 25 09:46:21 EDT 2009
Seth Price wrote:
> > r.li.setup is currently non-functional.
> > AFAICT, the immediate error is due to r.li.setup being a shell script,
> > while the build system expects a Python script named r.li.setup.py.
> If it's non-functional, what's the best way to exclude it from the
> build cycle? Do I even need to worry about it, or can I just run 'make
> install' to get everything except r.li.setup?
You don't need to worry about it.
Failure to build a module shouldn't affect anything other than that
particular module (the various r.li components are essentially treated
as separate modules, other than the fact that they all require
r.li.daemon).
