[GRASS-user] tables connection in database
Moritz Lennert
mlennert at club.worldonline.be
Fri Jun 26 11:36:39 EDT 2009
On 26/06/09 17:15, achim wrote:
>> Thats exactly the problem: It shows nothing.
>> None of my lines has any cat.
That's why you have to run v.category option=add as I indicated in a
previous mail.
> Another example where it works partly:
> | Type of Map: vector (level: 2)
> | Number of points: 1 Number of areas: 56
> | Number of lines: 0 Number of islands: 1
> | Number of boundaries: 255 Number of faces: 0
> | Number of centroids: 56 Number of kernels: 0
> | Map is 3D: No
> | Number of dblinks: 1
> successfully created a table with 57 entries
What is the problem ?
> And now: how to do the same with boundaries?
Why do you want your boundaries to have category values ? An area in
GRASS is defined by the combination of boundaries with a centroid and
the attribute data is attached to the centroid, not to the boundary.
If you really want cat values for your boundaries, again: use v.category
option=add type=boundary.
Have you read:
http://grass.itc.it/grass64/manuals/html64_user/vectorintro.html
http://grass.osgeo.org/wiki/Vector_Database_Management
Moritz
Moritz
