[GRASS-user] v.net table layers
achim
ak7 at jupiter.uni-freiburg.de
Mon Jun 29 11:28:56 EDT 2009
when I run v.net, shouldn't I see two layers in the table-manager?
Wouldn't it be much more comfortable if it was possible to tell the
modules to create a table?
I managed the problem with some difficulties. Its definitively not
obvious how the workflow should be.
The metadata from aaa_temp are (No of dblinks 1)
| Type of Map: vector (level: 2)
| Number of points: 218 Number of areas: 0
| Number of lines: 134 Number of islands: 0
| Number of boundaries: 0 Number of faces: 0
| Number of centroids: 0 Number of kernels: 0
| Map is 3D: No
| Number of dblinks: 1
Table-manager shows nothing!*
when I run v.category with report, I get:
v.category --overwrite input=aaa_temp at achim output=aaa_temp2 at achim
option=report type=point layer=2
Layer/table: 1/aaa_temp
type count min max
point 0 0 0
line 134 1 134
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 134 1 134
(I have to define an output-vector for report!???) <-----?
So I add a layer for the nodes myself
type=point layer=2
Vector map <aaa_temp2> already exists and will be overwritten
Table <aaa_temp2> linked to vector map <aaa_temp2> does not exist
Processing features...
Copying attribute table(s)...
DBMI-SQLite driver error:
Error in sqlite3_prepare():select * from aaa_temp where 0 =
1
no such table: aaa_temp
Unable to open select cursor: 'select * from aaa_temp where 0 = 1'
Unable to copy table <aaa_temp2>
Failed to copy attribute table to output map
Building topology for vector map <aaa_temp2>...
Registering primitives...
352 primitives registered
2678 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 218
Number of primitives: 352
Number of areas: 0
Number of isles: 0
v.category complete. 218 features modified.
v.category --overwrite input=aaa_temp2 at achim output=aaa_temp2 at achim
Layer/table: 1/aaa_temp2
type count min max
point 0 0 0
line 134 1 134
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 134 1 134
Layer: 2
type count min max
point 218 1 218
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 218 1 218
>>When I add a new table I get:
v.db.addtable map=aaa_temp2 at achim
Using vector map name as table name: aaa_temp2
ERROR: There is already a table linked to layer <1>
>>Although the connection information gives (*):
v.db.connect -p map=aaa_temp2 at achim
layer <1> table <aaa_temp2> in database </home/achim/grass/sqlite_db>
through driver <sqlite> with key <cat>
Vector map <aaa_temp2 at achim> is connected by:
>>So I delete the connection and build a new table:
Creating new DB connection based on default mapset settings...
Creating table with columns (cat integer)
The table <aaa_temp2> is now part of vector map <aaa_temp2 at achim> and
may be deleted or overwritten by GRASS modules
Select privileges were granted on the table
Reading features...
Updating database...
134 categories read from vector map (layer 1)
134 categories read from vector map don't exist in selection from table
134 records updated/inserted (layer 1)
Current attribute table links:
>>And another for layer 2:
v.db.addtable map=aaa_temp2 at achim layer=2
Using vector map name extended by layer number as table name: aaa_temp2_2
The table <aaa_temp2_2> is now part of vector map <aaa_temp2 at achim> and
Reading features...
layer <2> table <aaa_temp2_2> in database </home/achim/grass/sqlite_db>
218 categories read from vector map (layer 2)
218 categories read from vector map don't exist in selection from table
218 records updated/inserted (layer 2)
>>So now I can see the information in the table manager. And now I can
run network-tools, understanding what happens.
Comments welcomed,
Achim
