[GRASS-user] Calculating eigen values and %
varianceexplainedafter PCA analysis
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sun Mar 1 08:33:59 EST 2009
Nikos:
> > It should be the case with i.pca as well since eigen_VALUES_ (=represent
> > the variances of the original dimensions that are "kept" in each
> > component) are important for the interpretation of what exactly are each
> > of the components. But, i.pca just does not report the eigen_VALUES_.
> > At some point some C-expert needs to have a look in the code (i.pca) and
> > correct the "bug" which does not let the eigen_VALUES_ from being
> > printed.
Hamish:
> done in devbr6 (6.5svn) please test, I'm not a multivariate stats guru
> and may have done something dumb so didn't port to other branches yet.
> I changed the i.pca output to be like:
> Eigen (vectors) and values:
> PC1 ( -0.63 -0.65 -0.43 ) 88.07
> PC2 ( 0.23 0.37 -0.90 ) 11.48
> PC3 ( 0.75 -0.66 -0.08 ) 0.45
> As it was previously sent to stderr via G_message() I don't feel bad about
> breaking output text compatibility. I wanted to add "%" to the values but
> due to the sprintf()+strcat() method in the code that was a pain, so I
> didn't.
Wesley:
> > > If this is the case then both methods still differ significantly. Is
> > > this possible, and which should I use.
> > Please have a look at my comments/questions in link [2].
> > i.pca follows the "SVD" method. You performed the non-standartised PCA
> > using the covariance matrix. Note that you can use also the
> > standartised method by using the correlation matrix.
> does the r.mapcalc command at the end of the m.eigensystem help page*
> do that conversion, or ...? ie how can we test these against each other?
> how to do the standardized method?
We can easily cross-compare now. I will run my test in GRASS and R.
In GRASS:
* i.pca --> SVD without data centering method
* "r.covar" + "m.eigensystem" --> non-standardised PCA (about data
centering I am unsure here, I will investigate the _numbers_)
* "r.covar -r" + "m.eigensystem" # note the "-r" flag --> standardised
PCA (about data centering I am unsure, willing to test).
> [*] (is "\-" there a typo or some old mapcalc syntax?)
IMHO: yes. Maybe it's some forgotten _backslash_ !?
> also ISTR somebody (Dylan?) doing a comparison with the R-stats interface.
> It would be nice to run tests using the Spearfish imagery dataset. After
> my own tests I noticed it matched what was used in the m.eigensystem help
> page.
I will probably run the test with my own data. Since I just need to
copy-paste the commands. I don't have the spearfish dataset currently.
> my results follow.
> Hamish
> #Spearfish imagery sample dataset
> g.region rast=spot.ms.1
> # 'by-hand-method'
> G65> echo "3" > test_m.eigensystem # number of input maps
> G65> r.covar map=spot.ms.1,spot.ms.2,spot.ms.3 >> test_m.eigensystem
> G65> cat test_m.eigensystem
> 3
> 462.876649 480.411218 281.758307
> 480.411218 513.015646 278.914813
> 281.758307 278.914813 336.326645
> G65> m.eigensystem < test_m.eigensystem
> C The output is N sets of values. One E line and N V W lines
> C
> C E real imaginary percent-importance
> C V real imaginary
> C N real imaginary
> C W real imaginary
> C ...
> C
> C where E is the eigen value (and it relative importance)
> C and V are the eigenvector for this eigenvalue.
> C N are the normalized eigenvector for this eigenvalue.
> C W are the N vector multiplied by the square root of the
> C magnitude of the eigen value (E).
> E 1159.7452017844 0.0000000000 88.38
> V 0.6910021591 0.0000000000
> V 0.7205280412 0.0000000000
> V 0.4805108400 0.0000000000
> N 0.6236808478 0.0000000000
> N 0.6503301526 0.0000000000
> N 0.4336967751 0.0000000000
> W 21.2394712045 0.0000000000
> W 22.1470141296 0.0000000000
> W 14.7695575384 0.0000000000
> E 5.9705414972 0.0000000000 0.45
> V 0.7119385973 0.0000000000
> V -0.6358200627 0.0000000000
> V -0.0703936743 0.0000000000
> N 0.7438340890 0.0000000000
> N -0.6643053754 0.0000000000
> N -0.0735473745 0.0000000000
> W 1.8175356507 0.0000000000
> W -1.6232096923 0.0000000000
> W -0.1797107407 0.0000000000
> E 146.5031967184 0.0000000000 11.16
> V 0.2265837636 0.0000000000
> V 0.3474697082 0.0000000000
> V -0.8468727535 0.0000000000
> N 0.2402770238 0.0000000000
> N 0.3684685345 0.0000000000
> N -0.8980522763 0.0000000000
> W 2.9082771721 0.0000000000
> W 4.4598880523 0.0000000000
> W -10.8698904856 0.0000000000
> # 'all-in-one method' using r.covar+m.eigensystem:
> G65> (echo 3; r.covar spot.ms.1,spot.ms.2,spot.ms.3 ) | m.eigensystem
> Then, using the W vector, new maps are created:
> r.mapcalc 'pc.1 = 21.2395*map.1 + 22.1470*map.2 + 14.7696*map.3'
> r.mapcalc 'pc.2 = 2.9083*map.1 + 4.4599*map.2 - 10.8699*map.3'
> r.mapcalc 'pc.3 = 1.8175*map.1 - 1.6232*map.2 \- 0.1797*map.3'
> (is "\-" above a typo or some old mapcalc syntax?)
Probably a typo.
> which look highly similar (but not identical) to i.pca output maps.
It's ok. R print's out lot's of decimals. Perhaps the difference is due
to some rounding of the numbers.
> (after 'r.colors color=grey')
> # 'automatic method'
> imagery60:G6.5svn> i.pca in=spot.ms.1,spot.ms.2,spot.ms.3 out=spot_pca
