[GRASS-user] r.water.outlet     and     SELECT WHERE Maximum
    achim
    ak7 at jupiter.uni-freiburg.de
    Tue Mar  3 11:52:59 EST 2009
Hello,
today I have two questions...
No 1.
r.water.outlet doesn't produce the hole outlet. I chose coordinates E
and N from point coordinates. The point was converted from a raster-cell
via r.to.vect. For illustration I attach a screenshot.
No 2.
I'd like to select the raster-cell with the highest value. I converted
the raster to points and tried to select with SELECT WHERE. How can I
use an maximum-statement in it? I couldn't fix it out. Or is there
another way? (I use the default db)
Best regards,
achim
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname   : wateroutlet.jpg
Dateityp    : image/jpeg
Dateigr??e  : 34761 bytes
Beschreibung: nicht verf?gbar
URL         : http://lists.osgeo.org/pipermail/grass-user/attachments/20090303/152ea527/wateroutlet-0001.jpg
