[GRASS-user] i.landsat.rgb problem
Tim Holland
timothyholland at gmail.com
Thu Mar 5 02:07:08 EST 2009
Hello,
I am responding to an old (Jan 2008) post in the hopes someone can help me
out a bit. I am trying to use i.landsat.rgb, and am finding that after I do
so, the colour tables of the rasters I am using are changed to white (same
problem as Leonardo Lami had below).
I am very much a beginner grass user. Can someone please tell me how to use
the patch that Martin Landa provided below? It sounds like it will address
my problem, but I do not know how to load it / apply it. I am running Grass
6.3 through the plug-in on QGIS 0.11.0.
Thanks,
Tim
Martin Landa wrote:
> Hi,
> the attached patch should fix the problem with floating point arithmetic.
> Martin
> 2008/1/17, Leonardo Lami <lami at faunalia.it>:
>> Hi all,
>> i tried i.landsat.rgb on GRASS 6.3 but I have this error message and the
>> color tables of the three raster are setted with all values white.
>> I obtained this three brov raster from i.fusion.brovey applied on
>> Landsat images.
>> i.landsat.rgb -p red=brov.red at PERMANENT green=brov.green at PERMANENT
>> blue=brov.blue at PERMANENT strength=90
>> Processing [brov.red at PERMANENT] ..
>> /usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 36.9801: integer
>> expression expected
>> /usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 15.7707: integer
>> expression expected
>> Processing [brov.green at PERMANENT] ..
>> /usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 39.6825: integer
>> expression expected
>> /usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 15.1483: integer
>> expression expected
>> Processing [brov.blue at PERMANENT] ..
>> /usr/lib/grass/scripts/i.landsat.rgb: line 138: [: 24.107: integer
>> expression expected
>> /usr/lib/grass/scripts/i.landsat.rgb: line 141: [: 13.1111: integer
>> expression expected
>> Color table for <brov.red at PERMANENT> set to rules
>> Color table for <brov.green at PERMANENT> set to rules
>> Color table for <brov.blue at PERMANENT> set to rules
>> Thank you
>> Leonardo
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
> Index: scripts/i.landsat.rgb/i.landsat.rgb
> --- scripts/i.landsat.rgb/i.landsat.rgb (revision 29738)
> +++ scripts/i.landsat.rgb/i.landsat.rgb (working copy)
> @@ -71,6 +71,12 @@
> exit 1
> fi
> +# check if we have awk
> +if [ ! -x "`which awk`" ] ; then
> + g.message -e "awk required, please install awk or gawk first"
> + exit 1
> +fi
> # save command line
> if [ "$1" != "@ARGS_PARSED@" ] ; then
> CMDLINE="`basename $0`"
> @@ -116,7 +122,7 @@
> if [ 0 -eq $GIS_FLAG_P ] ; then
> for i in $RED $GREEN $BLUE ; do
> - g.message "Processing [$i] .."
> + g.message "Processing <$i>..."
> MIN=`r.univar -ge $i perc=2 | grep "^percentile_" | cut -d'=' -f2`
> MAX=`r.univar -ge $i perc=$BRIGHTNESS | grep "^percentile_" | cut
> -d'=' -f2`
> #echo "[$i]: min=$MIN max=$MAX"
> @@ -131,18 +137,14 @@
> ALL_MAX=0
> ALL_MIN=255
> -d'=' -f2`
> - #echo "[$i]: min=$MIN max=$MAX"
> - if [ $MAX -gt $ALL_MAX ] ; then
> - ALL_MAX=$MAX
> - fi
> - if [ $MIN -lt $ALL_MIN ] ; then
> - ALL_MIN=$MIN
> - fi
> + # echo "[$i]: min=$MIN max=$MAX"
> + ALL_MAX=`echo "$MAX $ALL_MAX" | awk '{if ($1 > $2) print $1; else
> print $2}'`
> + ALL_MIN=`echo "$MIN $ALL_MIN" | awk '{if ($1 < $2) print $1; else
> print $2}'`
> done
> - #echo "all_min=$ALL_MIN all_max=$ALL_MAX"
> + # echo "all_min=$ALL_MIN all_max=$ALL_MAX"
> r.colors $i col=rules << EOF
> 0% black
View this message in context: http://n2.nabble.com/i.landsat.rgb-problem-tp1881284p2427855.html
Sent from the Grass - Users mailing list archive at Nabble.com.
