[GRASS-user] r.terraflow on windows grass6.4 RC2 (osgeo4w)
massimo di stefano
massimodisasha at yahoo.it
Fri Mar 6 02:57:32 EST 2009
i'm tring to use grass on windows (osgeo4w.exe installer)
but "r.terraflow" give me some prblems
on the spearfish dataset :
r.terraflow.short elevation=elevation.10m at PERMANENT
filled=elevation10m.filled direction=elevation10m.direction
swatershed=elevation10m.watershed accumulation=elevation10m.accu
tci=elevation10m.tci d8cut=infinity memory=300 STREAM_DIR=C:\tmp
stats=stats3.out
MFD flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
raster elevation.10m is of type DCELL_TYPE --precision may be lost.
STREAM temporary files in /var/tmp (THESE INTERMEDIATE STREAMS WILL
NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE
SPACE PLEASE DELETE THESE FILES MANUALLY!)
file stats3.out exists - renaming.
ami_single_temp_name: mkstemp failed: : No such file or directory
Assertion failed: 0, file ami_stream.cc, line 75
This application has requested the Runtime to terminate it in an
unusual way.
Please contact the application's support team for more information.
in the file stats3.out i have :
Free Memory=-1
[0.0] Thu Mar 05 23:22:40 2009
Command Line:
C:\OSGeo4W\apps\grass\grass-6.4.0RC3\bin\r.terraflow.short.exe
elevation=elevation.10m at PERMANENT filled=elevation10m.filled
direction=elevation10m.direction swatershed=elevation10m.watershed
accumulation=elevation10m.accu tci=elevation10m.tci d8cut=infinity
memory=300 STREAM_DIR= mp stats=stats3.out
input elevation grid: elevation.10m
output (flooded) elevations grid: elevation10m.filled
output directions grid: elevation10m.direction
output sinkwatershed grid: elevation10m.watershed
output accumulation grid: elevation10m.accu
output tci grid: elevation10m.tci
[0.0] MFD flow direction
[0.0] D8CUT=999999986991104.000000
[0.0] Memory size: 300.00M (314572800) bytes
region size = 2.53M (2654802) elts (1398 rows x 1899 cols)
internal nodata value: -9999
it don't produce any output (onlt the stats file) and terminate
immediatly
have you any idea ?
i manually created the directory tmp in C:
p.s.
is these an osgeo4w probles?
do you know any grass-windos version that has r.terraflow working?
i'm really new to windos (never used it) ... so maybe i'm doing
something wrong :-/
i'm tring to make a foss-gis migration at university (idrology)
so i need a bit of time to port all the people on linux :-/
.... where r.terraflow works great and with really good results!
thanks to All,
Massimo Di Stefano
epifanio on irc.freenode.net /join gfoss
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090306/2137016b/attachment-0001.html
