[GRASS-user] Help needed in creating a thematic map
Thomas Adams Thomas.Adams at noaa.gov
Sat Mar 7 22:03:14 EST 2009
List:
I need to create a map in GRASS like the attached map. This needs to be
done on a daily basis, and it needs to be created by those who have
little GIS or GRASS knowledge or experience. The critical aspect is to
manually draw/digitize the critical "likely" or "possible" areas. And I
am struggling with v.digit doing this, but it's not the main problem.
The key issue is attaching attribute data to the polygonal regions that
define the period over which the "likely" or "possible" areas apply, as
the graphic shows. ALSO, the boundary data and the attributes (the valid
Date period) need to be exported to an ascii text file which is then
ftp'ed to a central location — the end users use their own software to
combine other such files to create a graphic (actually the one I am
showing). Now, combining the exported data into the format needed by the
end user is not an issue, it's really a matter of how to most
efficiently (easily) get the Starting and Ending dates into the
attributes of the polygons. Also, should I try to use a separate vector
map for each polygon of the same type ("likely" or "possible") or should
they be in different layers?
I'll have to write detailed instructions covering how to do this, but I
need to know how to do this first!
I'm very open to suggestions…
Regards,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090307/7b920cef/finalfop-0001.gif
