AW: [GRASS-user] Project map
    Stefanie Obmann
    stef_ob at gmx.at
    Wed Mar 11 10:09:46 EDT 2009
Hi!
I have another question concerning the projection of my vector layers.
I projected them by importing them from a mapset with geographic prj to a
mapset with lambert projection. V.out.ascii shows new coordinates which is
fine...
My question:
If I save my vector map as shp.-file for another GIS (ARCGIS in my case)
what projection does it use? My attribute table shows gg. Coordinates as in
GRASS. So do I have to project it another time?
(I also get a spatial reference alert back from the new GIS)
Thanks,
Steffi
-----Ursprüngliche Nachricht-----
Von: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] Im Auftrag von
Markus Neteler
Gesendet: Montag, 1. Dezember 2008 22:29
An: Stefanie Obmann
Betreff: Re: [GRASS-user] Project map
genau das macht ja v.proj... um die *Koordinaten* zu sehen:
GRASS 6.4.svn (lwd_lambert):/tmp > v.out.ascii HYD
189372.298871|389304.88446131|960|1
199811.87693732|399440.72876217|870|2
205231.53218899|392987.94788857|1295|3
186523.46925359|404389.42735205|1090|4
197282.90012946|409257.52605648|810|5
Problem geloest?
Bei Linien und Flaechen muss noch format=standard dazu.
v.db.select zeigt ja nur die Attribute, die natuerlich nicht beruehrt werden
von v.proj (auch wenn Koordinaten darunter sind).
Gruesse,
Markus
On Mon, Dec 1, 2008 at 10:05 PM, Stefanie Obmann <stef_ob at gmx.at> wrote:
> Hi,
> I tried what you advised me to do and it works.
> But what I really wanted to do is to get the map HYD into my location
> "lwd_lambert" where all my coordinates should be projected to lambert
> coordinates (unit: meters...) as the existing map in the location
> lwd_lambert.
> Isn't it possible?
> Thanks a lot!
> stef
von
> Markus Neteler
> Gesendet: Montag, 1. Dezember 2008 21:42
> An: Stefanie Obmann
> Cc: GRASS user list
> Stefanie,
> (have received offlist the location)
> I have tried with GRASS 6.4.svn on Linux, no problem:
> GRASS 6.4.svn (lwd_lambert):/tmp > v.proj HYD loc=ggcoord map=stat_map
> Building topology for vector map <HYD>...
> Registering primitives...
> 117 primitives registered
> 117 vertices registered
> Building areas...
>  100%
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
>  100%
> Number of nodes: 117
> Number of primitives: 117
> Number of points: 117
> Number of lines: 0
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> GRASS 6.4.svn (lwd_lambert):/tmp > v.db.select HYD
> cat|x|y|hoehe|val
> 1|10.542778|47.369722|960|-1.2
> When you run v.proj as indicated above, the v.db.select command
> won't show all the attributes as here?
> I suppose you use 6.3.0 Cygwin-GRASS, right (I forgot).
> Is there any other Cygwin-GRASS who could make this test?
> Markus
> On Mon, Dec 1, 2008 at 7:50 PM, Stefanie Obmann <stef_ob at gmx.at> wrote:
>> Dear users,
>> what can I do to import and project my map with geographic projection in
>> another location of as in my case Austria lambert projection?
>> v.proj loses every information (the whole content of the attribute
table).
>> I would appreciate your help!
>> Thanks,
>> stef
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
