[GRASS-user] troubles with i.landsat.rgb and d.rgb
Renae Mackas rmackas at sfu.ca
Sun Mar 15 21:26:55 EDT 2009
Thanks for your input, and sorry for the delayed response Hamish, I've been
away for the last while and haven't had much chance to work with Grass.
Hamish wrote:
> Renae Mackas wrote:
>> I have used r.ing.dal to import different Landsat TIFF images, and am now
>> trying to superimpose red, green, and blue spectral bandsto get  "real
>> colour" images.
>> I am under the impression that I need to use i.landsat.rgb to
>> auto-balance the colours of the LANDSAT images I am using.
> you do not "need" to use i.landsat.rgb, it just helps brighten things up
> if the image comes out rather dark. example:
>   http://bambi.otago.ac.nz/hamish/grass/landsat/
> The reason that I wanted to try and use i.landsat.rgb is that when I have
> been doing r.composite with the Landsat images, the resulting composite
> images come out with a coloured tinge to them (I am putting together
> images of sea ice formations, and most r.composite images come out with a
> pinkish/purple tinge). I thought I might be able to avoid this using
> i.landsat.rgb.  Perhaps this was an incorrect assumption?
>> I am using a PC, using the native version.
> does that mean you are running MS Windows?  native or cygwin version?
> (sorry to be overly pedantic, but consider that many run linux on a PC,
> and that historically many/most? GRASS users use some flavour of Linux)
> Yes, I am using MS windows, using the native version
>> and when I run the command:
>> i.landsat.rgb red=020.020.2000.055_B30
>>    green=020.020.2000.055_B20
>>    blue=020.020.2000.055_B10
>> a microsoft windows window pops up that informs me " r.univar.exe has
>> stopped working- a problem caused the program to stop working correctly.
>> Windows will close the program and notify you if a solution is vailable".
>> As long as I continue to run the i.landsat.rgb command,
>> this window continues to pop up.
> can you run "r.univar 020.020.2000.055_B10" from the command prompt?
> Yes, I could run this.
>> Have I made a mistake somewhere??
> don't really know. might be an install problem.
> can you view the scene ok in QGIS? (www.qgis.org)
>> Also, once (if?) I do get i.landsat.rgb to work, will the map display
>> window automatically show me the superimposed images??
> no. if you are currently viewing the layers you have to do a "hard"
> redraw as the GUI isn't aware that the colors have changed behind its
> back and the existing view may be partially cached.
> How do I do a "hard" redraw to be able to see the result of i.landsat.rgb?
> What I ultimately want is a mosaic image of multiple Landsat images.  If I
> do end up using i.landsat.rgb, do end up doing the "hard redraw" with my
> final mosaiced image, or do I have to do it seperately with each image
> that I want to put into the mosaic?
>> Also, I have tried just running d.rgb on the same images:
>> d.rgb red=020.020.2000.103_B30 blue=020.020.2000.103_B20
>> green=020.020.2000.103_B10
> if this is the native build d.rgb shouldn't work from the command prompt,
> as there are no xmon to draw to (d.mon + UNIX's X-Windows). Instead use
> the 'Add RGB or HIS layer' button from the GIS manager.
> the cygwin version uses X-Windows (aka X11) and so allows xmons.
> I tried using the button, and it displayed well, thank you.
> good luck,
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/troubles-with-i.landsat.rgb-and-d.rgb-tp2316681p2483705.html
Sent from the Grass - Users mailing list archive at Nabble.com.
