[GRASS-user] EPSG 3035
Moritz Lennert
mlennert at club.worldonline.be
Wed Mar 25 12:24:34 EDT 2009
On 25/03/09 16:57, Laura Poggio wrote:
> Dear all,
> I am starting to use GRASS and I am trying to set up a location with the
> LAEA ETRS89 projection (EPSG 3035).
> First I set up the location using the EPSG code and the I tried to
> import a geotiff with the same projection (created with gdal_translate).
> However I got the error "Projection of dataset does not appear to match
> current location".
> Then I set up the location using the georeferenced file itself, I tried
> to import the same file and I got the same error.
> I can manage to import the file using the -o option and over-riding
> projection check, but I would like to understand and possible solve the
> problem.
Your file might be georeferenced, but does not contain the information
about the system it is georeferenced in. In that case, grass will always
complain that it cannot guarantee a match.
If you are sure that it is referenced in 3035, then you have to use the
-o option.
Moritz
