[GRASS-user] Automatic Orthorectification
    Jachym Cepicky
    jachym.cepicky at gmail.com
    Thu Mar 26 02:57:13 EDT 2009
the GCPs are located in each image at known locations, you can create
necessary files in a batch script:
 - you have to create the group for each image (i.group)
 - you have to set the target and ref files for the group (i.target)
 - you have to create the POINTS file - manually
try to rectify one image by hand and then see grassdata/LOCATION/MAPSET/group/GROUP/*
however, if the position of GCPs is unknown to you, I'm affraid, you
have to do it by hand
jachym
On Wed, Mar 25, 2009 at 03:04:43AM -0700, Petrone Orlando Mauro wrote:
> Hi to all,
> I'm trying to use GRASS 6.4 (installed on UBUNTU) to realize a system to automate the orthorectification process.
> I have a group of little images (chip of 256x256 pixel) that I want to use to orthorectify an image.
> Can grass use the little chip to create the RPC polynomial without any external action? I try i.points.auto, but I must set the GCP manually...
> Thank you
> View this message in context: http://n2.nabble.com/Automatic-Orthorectification-tp2531561p2531561.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/JachymCepicky.pgp
Key fingerprint: 0C6D 0EAE 76BD 506C F299  ED8A C8AB 74B8 08D4 E08F
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090326/87aead84/attachment.bin
