[GRASS-user] EPSG 3035
Laura Poggio
laura.poggio at gmail.com
Thu Mar 26 03:39:07 EDT 2009
The output of the g.proj -w command is:
WARNING: Unable to initialise PROJ.4 with the following parameter list:
+a=6378137 +rf=298.257222101 +no_defs +towgs84=0.000,0.000,0.000
WARNING: The error message: projection not named
WARNING: Can't parse GRASS PROJ_INFO file
WARNING: g.proj: Unable to convert to WKT
Then I think there is some problem
Thank you very much
Laura
2009/3/25 Moritz Lennert <mlennert at club.worldonline.be>
> On 25/03/09 18:05, Laura Poggio wrote:
>> The output of gdalinfo on the file is
>> Driver: GTiff/GeoTIFF Files:
>> data/JRC/map/DTM/ast1.tif Size is 360, 364
>> Coordinate System is:
>> PROJCS["ETRS89 / ETRS-LAEA",
>> GEOGCS["ETRS89",
>> DATUM["European_Terrestrial_Reference_System_1989",
>> SPHEROID["GRS 1980",6378137,298.2572221010042,
>> AUTHORITY["EPSG","7019"]],
>> AUTHORITY["EPSG","6258"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4258"]], UNIT["metre",1,
>> AUTHORITY["EPSG","9001"]],
>> AUTHORITY["EPSG","3035"]]
> Mmmh, so coordinate system info is included and GRASS should recognize it.
> Could you send the output of g.proj -w in the location you want to import
> the file into ?
> Moritz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090326/c5855e45/attachment.html
