[GRASS-user] error in r.fillnull
    Markus Neteler
    neteler at osgeo.org
    Tue Mar 31 17:26:43 EDT 2009
2009/3/31 Martin Schweizer <schweizermartin at students.unibe.ch>:
> Hi
> I have the following Problem: I like to fill some NULL areas in a raster
> map. This is the outcome:
> GRASS 6.4.0RC3 (Romanum5):~ > r.fillnulls input=Hangneigung output=Hang0
> r.to.vect komplett.
> Interpolating points
> /opt/grass/scripts/r.fillnulls: line 184: [: -lt: unary operator expected
> Note: The following warnings may be ignored.
> Removing raster <MASK>
> /opt/grass/scripts/r.fillnulls: line 216: [: -ge: unary operator expected
Ah, too bad - this is a problem of using a non-English locale!
The code above line 184 looks like this:
POINTSNUMBER="`v.info map=${VECTTMP} | grep 'Number of points' | awk
'{print $5}'`"
Since it searches for 'Number of points' but gets in German locale
'Anzahl Punkte'
not a single point is found. The correct line is
POINTSNUMBER="`v.info -t map=${VECTTMP} | grep points | cut -d'=' -f2`"
You may just edit the script locally to fix that.
Found the same in v.centroids, both fixed in 6.4.svn, 6.5, and 7.
Thanks for reporting it,
Markus
