[GRASS-user] Building GRASS on Windows
Colin Nielsen colin.nielsen at gmail.com
Fri May 1 13:16:42 EDT 2009
Good to hear! I have had some problems getting wxpython running in
6.5, did you solve this or are you running tcl/tk?
-Colin
On Fri, May 1, 2009 at 8:26 AM, Darren Cope <darrencope at gmail.com> wrote:
> I finally found some time to get back at this.  I now have Grass 6.5.0
> running in Windows using the process at:
> http://trac.osgeo.org/grass/wiki/CompileOnWindows  Thanks to those who have
> been maintaining that information!
> v.net.iso now runs lightening fast (I can finish in 5 minutes what did not
> finish in several days in 6.4.0) so I will be continuing my work with that
> soon!
> Cheers, and thanks again!
> Darren Cope
> http://dmcope.freeshell.org
> http://bluesignweekly.blogspot.com/
> On Thu, Mar 19, 2009 at 8:31 AM, Colin Nielsen <colin.nielsen at gmail.com>
> wrote:
>> A MinGW package was missing on the wiki page, my fault not yours. I've
>> added it, get "mingw-runtime" and get "bin-utils" too while you're at
>> it. Both are now on the wiki. Sorry for the error.
>> -Colin
>> On Wed, Mar 18, 2009 at 8:37 PM, Darren Cope <darrencope at gmail.com> wrote:
>> > Hi all,
>> > I'm following along with the instructions here:
>> > and am getting stuck at Step 5 under PDCurses.  When running:
>> > make -f mingwin32.mak DLL=Y all
>> > The following error occurs:
>> > $ make -f mingwin32.mak DLL=Y all
>> > gcc -c -O2 -Wall -I.. -DPDC_DLL_BUILD ../pdcurses/addch.c
>> > In file included from ../curspriv.h:25,
>> >                  from ../pdcurses/addch.c:14:
>> > ../curses.h:50:57: stdio.h: No such file or directory
>> > ../curses.h:928: error: syntax error before '*' token
>> > ../curses.h:1010: error: syntax error before "FILE"
>> > ../curses.h:1027: error: syntax error before "FILE"
>> > make: *** [addch.o] Error 1
>> > Any thoughts?  I'd really like to get a new version built so I can play
>> > with
>> > v.net.iso improvements, but am struggling!
>> > Darren Cope
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
