[GRASS-user] Point count with large vectors
Moritz Lennert
mlennert at club.worldonline.be
Mon May 11 04:31:53 EDT 2009
On 09/05/09 00:51, Richard Chirgwin wrote:
> Hi all,
> I'm not sure if this has been solved before.
> I have two large points files (>20,000 sites), and I want to find the number of
> points in A falling within a given distance of the points in B. So the desired
> output would be:
> Cat Point count from B
> 1 10
> 2 3
> 3 12
> ...etc
> I can use a buffer from Map A and run v.distance, but it takes an extremely long
> time, so suggestions would be welcome!
Don't know if this would be much faster (what takes a long time in your
approach ?), but you could use only v.distance to create a distance
matrix (-a), and setting the threshold dmax to your distance.
Then a simple aggregate query on the reulting table should give you what
you need.
Moritz
