[GRASS-user] v.vol.rst basic questions
Christian Ferreira
chris.for.lists at googlemail.com
Mon May 11 11:06:47 EDT 2009
Hi Hamish,
stepping back a bit from the 3D, does any one have a comment about
> the appropriateness of using v.surf.rst in lat/lon locations?
So, I have multibeam data covering the coast of Ecuador and Peru.
And Since this data was in Lat-Long, as well the stations lists, I just
tried
to use the same format.
Personally, I try to use Lat-Long because my "working areas" are normally
big.
did you get a result? (be a "try it and find out" experimentalist :)
Apparently I have results see bellow, and I see it on nviz.
http://picasaweb.google.com/chris.for.lists/Map#5334573425418213906
| Layer: cdt_volume2 at PERMANENT Date: Mon May 11 16:06:29
2009 |
| Mapset: PERMANENT Login of Creator:
christian |
Transect11 |
| DataBase:
/Users/christian/Work/M77/GRASS |
| Title: ( cdt_volume2
| Timestamp:
none |
| Type of Map: 3d cell Number of Categories:
0 |
| Data Type:
double |
| Rows:
359 |
| Columns:
3835 |
| Depths:
10 |
| Total Cells:
13767650 |
| Projection: Latitude-Longitude (zone
0) |
| N: 10:57:00.288311S S: 11:03S Res:
0:00:01.001982 |
| E: 77:45:13.757688W W: 78:49:12W Res:
0:00:01.000845 |
| T: 0 B: -2200 Res:
220 |
| Range of data: min = 2.56193161 max =
12.80138111 |
| Data
Source: |
| Data
Description: |
| generated by
v.vol.rst |
Comments: |
| v.vol.rst input="ctd_3d" cellinp="bathy" wcolumn="temperatur"
tensio\ |
| n=40. smooth=0.1 segmax=100 npmin=200 dmin=0.01 wmult=1.0
zmult=0.00\ |
| 0278
elev="cdt_volume2" |
Actually, here I have a very strange thing...
If I run g.list rast3d, I can list my interpoled volume.
But if I try to run "r3.info ctd_volume2" in the command line I get a
message
telling "ERROR: Raster map <ctd_volume2> not found", but if I use the GUI
for
r3.info is possible to read the file (like above).
The same happens if I try start nviz with:
"nviz bathy volume=ctd_volume2"
So, here is something wrong, because I'm able to manipulate the file just
using the GUI...
I don't unterstand what? Maybe a bug?
so res ~ 30m?
Yes!
it is approx 1 degree wide, and even though it is on the edge of UTM 18
> you probably can get away with reprojecting half way into the next zone
> with acceptable distortion. else just set up a custom transverse mercator
> with a lon_0 of 78W instead of 75W to work in.
> as you have already guessed, giving x,y,z all using the same units
> removes a lot of problems.
Aham. So, this means that v.vol.rst is not supposed to be used with
Lat-Long?
If yes, I will definitely quit this Lat-Long location and go to UTM.
> I don't know, I expect it doesn't know about lat/lon units so it may
> consider depths to be in degrees too. but maybe that's ok -- once it
> is stretched back to meters the effect will be to induce a barrier to
> strong vertical mixing, versus the relative ease of horizontal mixing,
> which is in fact somewhat realistic. (at least it's wrong in the right
> direction)
> NVIZ does know to scale lat/lon maps back to meters for 2.5D raster
> maps*, probably it scales 3D volumes too?
> [*] that still requires some heavy refinement though
I don't know, but I'd guess it is "dumb". Also I don't know if dmin
> is considered in the voxel cube or just in horizontal slices?
> Something you might try is to divide the depths by 1852*60 (approx
> meters in a deg lat) to convert the depths into degree units, but
> really reprojecting into UTM or so would be my first try. you are
> somewhat lucky that you are working near the equator.
Well, after trying the whole Friday with nearlly no results, I'm quite
convinced
that v.vol.rst is not dumb.
And, I was not able to set very well "dmin".So, the results were strange.
Here is a try adjusting res3 to 0.000278 (30m), zmult to the same number and
dmin to 0.001
> actually the thing that I worry about there is not the x,y with z using
> different units (easily fixed by reprojecting to a planimetric
> projection), it is that all of your data points are essentially in a
> single straight line, and what effect that has on the 3D algorithm?
As long I'm capable to produce a 2D slice along the transect/volume
to show the data, the rest would not matter for the moment.
But I understand that interpolation algorithm is having a hard time when
trying to
interpolate the cells away from the transect.
This was a test... the best is probably how you are saying below...
> perhaps remake your axes as distance-along-transect vs. depth? then
> treat distance as the x axis and depth as the y axis and make a simple
> 2D interpolation? (classic matlab contourf(), shading flat or masked
> v.surf.rst) then somehow rotate it to be a 1 cell wide 3D raster* to
> throw up?
> [*] I haven't (yet) written a r3.{in|out}.mat but I suppose it would
> not be too hard for you to write a little script to create a single
> slice to import with r3.in.ascii (see the help page examples) to rotate
> the 2D slice to a vertical one?
Well, is not better (or possible) to set in GRASS a temporary region so thin
(in the N-S axis) to create this 2D slice?
Otherwise, I will simply do it like you said before... creating a 1 cell
wide 3D raster.
PS: I using for this tests GRASS in a Macbook/Intel on Mac OS X 10.5, and
using
the binaries from http://www.kyngchaos.com/software:grass/
> check out Helena's Chesapeake Bay interpolations:
> http://grass.osgeo.org/screenshots/viz.php (near the end)
> http://skagit.meas.ncsu.edu/~helena/gmslab/viz/ches.html<http://skagit.meas.ncsu.edu/%7Ehelena/gmslab/viz/ches.html>
> and also maybe some r3.out.vtk stuff with Paraview or Vis5D?
I'm trying to simply do all using GRASS... maybe is not the best choice.
Regards,
Chris
Christian Ferreira
Oceanographer
IFM-GEOMAR Leibniz-Institute of Marine Sciences
Kiel - Germany
Poseidon Linux team
http://www.poseidonlinux.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090511/a7e92c58/attachment.html
