[GRASS-user] RE:How to find shortest distances from the
investigation point to the shoreline
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Wed May 13 05:06:49 EDT 2009
Hi all,
May be our friend Yasuo shimada
are suffering for the absence of
binary version newest than 6.2 on linux?
regards,
milton
2009/5/13 Hamish <hamish_b at yahoo.com>
> sgw00412 wrote:
> > I tested by two kinds of geographical coordinate systems by
> > using the same data.
> > One of the geographical coordinate systems is UTM54, and
> > the remainder is wgs84.
> > data :point vector data (10 points) and a line vector data
> > OS: grass 6.2.3 on Cygwin.
> > As a result, the case of UTM54 obtained the distance of meter.
> > On the other hand, wgs84 obtained the distance of decimal value.
> > So, I guess that the decimal value of wgs84 is a degree of
> > latitude longitude.
> > Grass manual wrote that "...In lat-long locations v.distance gives
> > distances (dist and to_along) in meters not in degrees calculated as
> > geodesic distances on a sphere.."
> http://www.ces.iisc.ernet.in/grass/grass64/manuals/html64_user/v.distance.html
> > Though this manual is version 6.4, the manual of version
> > 6.2 is not written it.
> > Is this interpretation correct?
> > If it is so, please teach me the method of converting the
> > decimal value into the meter.
> Yes, version 6.2.3 is giving distances in (useless) degree units. This
> was fixed in Jan 2008 by Martin to use geodesic distance in meters, so
> GRASS 6.3.0 and the upcoming 6.4 do return meters. But 6.2.3 was
> released in Nov 2007 and so is too old to have that fix.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090513/12d9135c/attachment.html
