[GRASS-user] how to update one attribute of a small vector map?
    Micha Silver
    micha at arava.co.il
    Mon May 18 11:24:03 EDT 2009
Offenthaler Ivo wrote:
> What would you suggest as the most convenient way to update a small (60 points) vector map? E.g. a map's attribute "pollution_level" for a given point-ID (attribute "sitecode") has to be updated, based on some plain text output (columns "sitecode" and "pollution level") of another software?
In a command shell, you might find something like this will do it:
while read sc pl
    do
    echo "UPDATE <vect_point_map> SET pollution_level=$pl WHERE
sitecode=$sc" | db.execute
done < plain_text_file
This assumes that the plain_text_file is just two columns, sitecode and
pollution_level. You can loop thru the new values any way that's
convenient. The line:
echo "UPDATE .... WHERE ..." | db.execute
is what does the work.
Micha
> Many thanks in advance! Ivo
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
