[GRASS-user] Overlap 2 paths
Stefano elstefen at gmail.com
Mon May 18 15:45:46 EDT 2009
Hi all.
i'm looking for an hint.
i've two path that has same pieces in common, i would found the pieces
shared by both of them.
Is enough if i can extract only the single pieces in vect. there's the
possibility to extract also the  cat information?
i looked at the v.overlay but didn't work.
any other ideas?
thanks.
Stefano
