[GRASS-user] r.series g.mlist unhappy together
Daniel Victoria daniel.victoria at gmail.com
Tue May 19 21:37:41 EDT 2009
What is the exact command line you used and the error message? Because
in your first email the error was due to the wrong use of quotes. The
entire g.mlist command should be inside back ticks (` `), with no need
for quotes inside the g.mlist line, exactly like Nikos suggested...
On Tue, May 19, 2009 at 9:44 PM, saewan koh <saewan at gmail.com> wrote:
> Hi Nikos,
> Thanks for the super fast response.
> I tried what you suggested but the same error messages came up.
> If you have another suggestion please let me know,
> Thanks again,
> Saewan
> On 19-May-09, at 6:12 PM, Nikos Alexandris wrote:
>> saewan:
>>> I am trying to use g.mlist to gather files to use with r.series.
>>> r.series input="`g.mlist pat='*1987*pdds' sep=,`" output=test1987dd0
>>> method=sum
>> Try this:
>> r.series input=`g.mlist pat=*1987*pdds sep=,` output=test1987dd0
>> method=sum
>> Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
