[GRASS-user] Re: IN: raster-flow-direction OUT:vector-network?
	(achim)
    Margherita Di Leo
    diregola at gmail.com
    Wed May 20 13:31:34 EDT 2009
Hi Achim,
i usually produce the river network starting from the flow accumulation,
not from the flow direction. If you have a raster elevation map you can
get it using r.watershed.
Then, i make as follows:
r.mapcalc 'log_accumulation=log(abs(accumulation)+1)'
r.mapcalc 'inf_river=if(log_accumulation>6)'
6 is a treshold value for the log_accumulation, it is a good value for
me but you maybe can try other values. It produces a binary map.
Then:
Raster -> Transform features -> Thin linear features to reduce at 1pixel
the lines of the binary raster inf_river and create the new file in_river.
Finally, with r.to.vect you can transform the raster in_river in a
vector map.
Hope this helps
Margherita
> Message: 8
> Date: Wed, 20 May 2009 16:45:56 +0200
> From: achim <ak7 at jupiter.uni-freiburg.de>
> Subject: [GRASS-user] IN: raster-flow-direction OUT:vector-network?
> To: grass-user <grass-user at lists.osgeo.org>
> Message-ID: <4A1417A4.3040701 at jupiter.uni-freiburg.de>
> Content-Type: text/plain; charset="iso-8859-15"
> Hello,
> I am searching for a good idea to convert a raster-flow-direction map
> into a vector-network map.
> Probably I will have to write a script. If it is possible at all...
> In case of writing a script it mean to me: how to produce a line within
> r.mapcalc?
> Has anyone a hint?
> Cheers,
> achim
> PS:for illustration I attached a little picture
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: not available
> Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090520/6198f353/rasterflow-to-network.png
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> End of grass-user Digest, Vol 37, Issue 35
Ing. Margherita Di Leo
Ph.D. Student
Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata
Campus Macchia Romana
85100 - Potenza
Italy
Office: +39-0971205363
Fax: +39-0971205160
E-mail: dileomargherita AT gmail DOT com
Skype: dileomargherita
URL: http://www.difa.unibas.it/A_Manager_PP.do?azione=visualizzaHomePage&id=106
