[GRASS-user] Help with creating bathymetric maps
Alyre alyre.chiasson at umoncton.ca
Wed May 20 15:26:52 EDT 2009
Hello again,
This is all great info and I am sure the links will be helpful. Also the
heads up on several issues are of great value. I haven't given up yet but
find myself occasionally stubbing over  unfamiliar terms such as a quadtree
(but I will look it up). I do have the last GRASS book but can't claim to
understand too much even though I have all three editions. The arrival of
QGIS has helped a lot as well as the associated tutorials. Getting my data
in is no longer a problem (projections) as well as simple manipulations. I
currently have installed GRASS 6.4, QGIS (Kore 1.0) and find FWtools
helpful. I have also found the book Desktop GIS to be useful.
If I can sort all of this out I may following your suggestion of put
together a tutorial, however, I feel someone more knowledgeable  would have
to review it. There might be aspects I have overlooked or better ways of
accomplishing the same thing.
I will do my homework and might be back with a few more questions. By the
way I think v.extract will get me my shoreline boundaries as points and then
I can merge the two vector files (shoreline and depths), then do the raster
conversion.
Thanks for the help.
Alyre
Hamish wrote:
> ..... and since you are in the maritimes you might be interested to see
> what Bob Covill is doing with GRASS and other open source tools:
> http://www.tekmap.ns.ca/
> really a mix of GRASS, Postgis (for really massive datasets), GDAL tools,
> and GMT are all very useful if each is used to its strength.
> I must say though, GRASS's r.contour does a really brilliant job if the
> input raster map is of good quality.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Help-with-creating-bathymetric-maps-tp2896653p2948118.html
Sent from the Grass - Users mailing list archive at Nabble.com.
