[GRASS-user] r.series g.mlist unhappy together
Markus Neteler
neteler at osgeo.org
Wed May 20 16:18:41 EDT 2009
On Wed, May 20, 2009 at 9:58 PM, saewan koh <saewan at gmail.com> wrote:
> Hi Markus,
> On 20-May-09, at 1:48 PM, Markus Neteler wrote:
> Hi Saewan,
> On Wed, May 20, 2009 at 8:51 PM, saewan koh <saewan at gmail.com> wrote:
> The last weird thing i just discovered is that when i use g.mlist on its own
> - it will not run if i use quotations as in g.mlist rast pat="SmrDDT0Tot*"
> What happens exactly?
> When i run
> g.mlist pattern="*1986*dd5s"
> I get the following output.
> (Wed May 20 13:49:57 2009) Command finished (0 sec)
> If i run g.mlist pattern=*1986*dd5s
> 1986_4_12_4_18_dd5s
> 1986_4_19_4_25_dd5s
> 1986_4_26_5_2_dd5s
> 1986_4_5_4_11_dd5s
> etc.
Bingo I got it thanks to Martin's comment: you use (did you mention?)
the wxGUI command line which is currently "eating" the quotes.
A known bug which requires some work to be fixed.
Solution for today: launch the commands in the real terminal.
Markus
