[GRASS-user] copying raster between Mapsets
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Wed May 20 16:27:26 EDT 2009
Hi Markus,
you are rigth, the error was as you showed.
But may be I made a mistake, and I dont know how fix it.
I have two Project Location (PL_A and PL_B), and on each one I have
@PERMANENT mapsets.
I thougth that if rename the PERMANENT (like TEMP_mapset) on PL_B and copy
the directory to PL_A, than when I load PL_A I can access both PERMANENT and
TEMP_mapset.. But grass not recognize automatically @TEMP_mapset.
My mapsets has no projection (it is a XY unprojected location).
Any help are welcome.
bests
milton
2009/5/20 Markus Neteler <neteler at osgeo.org>
> On Wed, May 20, 2009 at 9:04 PM, Milton Cezar Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
> >  Hi GrassGurus,
> > I have a Project Location with two mapsets, like:
> > MyProjLocation
> >     +PERMANENT
> >     +TEMP_mapset
> > Now I need to move some rasters from @PERMANENT to @TEMP_mapset
> > I tryed something like:
> >    g.copy rast=A @PERMENENT,A @TEMP_mapset (without spaces)
> > But it not works.
> What is the error? I suspect
> Illegal filename. Character <@> not allowed.
> Solution: don't specify @TEMP_mapset in the target name since you
> write to the current mapset.
> So:
> g.copy rast=A at PERMANENT,A
> will do it.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090520/9f33962d/attachment-0001.html
