[GRASS-user] use rgbcolumn for vector line in vareas ps.map
maning sambale
emmanuel.sambale at gmail.com
Fri May 22 01:41:41 EDT 2009
I have an vector polygon where an attribute column defines the rgb
color for ps.map. The problem is, vareas options does not allow to
use the rgbcolumn for line color. Setting the width to very small
doesn't help either. Is there a way to disable line render in vareas.
Or should I split the vector polys into separate layer of polygon
categories (too many).
example below:
vareas forestcover_2002
masked y
width .0000001
rgbcolumn rgb
cats 1-9999999
label Forest
end
Any other elegant solution (within ps.map)? Using GRASS6.4 svn
compiled ages ago.
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
