[GRASS-user] Re: GRASS-6.4 error
William Kyngesburye woklist at kyngchaos.com
Fri May 22 17:44:06 EDT 2009
On May 22, 2009, at 3:48 PM, Lee Eddington wrote:
> I am trying to run GRASS-6.4 for Mac OS X for the first time as a
> GRASS user and am having the following problem.
> and an error window that says "Error setting region (Problem with
> g.region?): child killed: trace trap".  There is an "OK" button on
> this window, but when I click on it nothing happens.
> new-host-2:~ lee$ /Library/Frameworks/GDAL.framework/Versions/1.6/
> Programs/gdalinfo
> dyld: Library not loaded: /usr/lib/libiconv.2.dylib
>  Referenced from: /Library/Frameworks/GDAL.framework/Versions/1.6/
> Libraries/libpq.dylib
>  Reason: Incompatible library version: libpq.dylib requires version
> 7.0.0 or later, but libiconv.2.dylib provides version 5.0.0
> Trace/BPT trap
> So I guess I need a more current version of libpq.dylib, but I'm not
> sure on how to go about getting and properly installing it.
There was a problem with the GDAL 1.6.1 framework on OSX Tiger where I
bundled the Leopard libpq by accident.  It should be fixed in GDAL
1.6.1-3.
When GDAL has a problem, it doesn't show up when you start GRASS, only
when you try to run a module.
PS. the mailing lists are a better place to ask questions - others may
have a similar problem and are either too timid to ask, or don't know
what to ask, or it may not be a direct problem with my binary
packages.  And any answers will then be available to others in the
archives.  (I'm cc-ing the user list)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
