[GRASS-user] Generate DEM with point and line vector
leonidas
leonidas_liakos at yahoo.gr
Tue May 26 14:08:32 EDT 2009
I need to generate a DEM using a line vector file (contours, step=20m, some
are disjoined) and also combine a second point vector file with heights.How
can I achieve that with Grass?In the contours file there is also the
coastline (height=0).Will that produce any error?Thank you, Leonidas
View this message in context: http://n2.nabble.com/Generate-DEM-with-point-and-line-vector-tp2976281p2976281.html
Sent from the Grass - Users mailing list archive at Nabble.com.
