[GRASS-user] error in ps.map scalebar units argument
maning sambale emmanuel.sambale at gmail.com
Tue May 26 23:28:28 EDT 2009
Ahh no units option in my grass version:
/250k_layout.map
+ REGION=surigao_test_reg
+ TITLE=SURIGAO
+ PCGS=2535
+ g.region region=surigao_test_reg res=100
+ ps.map out=surigao_test_reg.ps
where      x y
length	length
height	height
segment	no_segemnts
numbers	no_labels
fontsize   fontsize
background [Y|n]
enter 'end' when done, 'exit' to quit
+ echo 'finished generating postscript map of SURIGAO'
[Raster MASK present]
I'll try a new grass version then.
On Tue, May 26, 2009 at 7:35 PM, Hamish <hamish_b at yahoo.com> wrote:
> maning wrote:
>> GRASS 6.4.svn
>> ERROR: units kilometers : illegal request (scalebar)
> that indicates it doesn't understand "units" (as opposed to km,miles,etc
> qualifier being bad).
> I don't know why it doesn't work for you.
> can you try putting in your script:
>  scalebar s
>   help
>   exit
>   end
>  end
> and see if "units   auto|meters|kilometers|feet|miles|nautmiles" is
> there in the output?
> All I can suggest is to 'make clean', 'svn update' to the latest 6.4svn
> (checking for 'C'onflicts),  and rebuild.
> And make sure there are no invisible non-ascii chars instead of spaces
> or tabs on that line.. but I doubt that.  can you email me the script
> or check with a hexdump program?
> worst come to worst you can add the "kilometers" text in with the
> text x% y% command by hand, then open the PS file in your favourite
> industrial strength text editor and search for the "ZB (10000) PB",
> (20000), (30000) m text and edit them to be like (10) (20) (30).
> [a wonderful trick for quickly fixing typos in the hardcopy]
> That should be pretty much near the end of the file.
> Hamish
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
