[GRASS-user] Error building v.label.sa in Grass 6.5
Wolf Bergenheim
wolf+grass at bergenheim.net
Thu May 28 14:39:12 EDT 2009
I fiexed the vector makefile to only build v.label.sa if freetype is
enabled in develbranch_6.
--Wolf
On 05/28/2009 05:29 PM, Markus Neteler wrote:
> On Thu, May 28, 2009 at 3:19 PM, Eric Patton <epatton at nrcan.gc.ca> wrote:
>> I'm running into an error building v.label.sa using today's svn checkout
>> of Grass 6.5, rev 37569.
>> Changing directory to grass6_devel/vector/v.label.sa and running make
>> clean then make results in:
>> $ make
>> test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
>> gcc -I/usr/local/grass6_devel/dist.x86_64-unknown-linux-gnu/include -g -O2 -I/usr/local/include -I/usr/local/include -DPACKAGE=\""grassmods"\" -I/usr/local/grass6_devel/dist.x86_64-unknown-linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/annealing.o -c annealing.c
>> In file included from labels.h:20,
>> from annealing.c:15:
>> /usr/include/ft2build.h:56:38: error: freetype/config/ftheader.h: No such file or directory
> To make the header visible to GRASS on my system, I have to configure:
> ./configure [...] --with-freetype
> --with-freetype-includes=/usr/include/freetype2
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Wolf Bergenheim (wolf+grass at bergenheim.net)
