[GRASS-user] Re: /usr/lib/grass/scripts/r.in.wms: line 439:
/usr/lib/grass/etc/r.in.wms/r.in.gdalwarp: Argument list too long
Hamish
hamish_b at yahoo.com
Fri May 29 08:30:25 EDT 2009
Seb wrote:
> I should have mentioned that before trying with 'gdalwarp',
> I tried what 'r.in.wms' does with 'r.in.gdalwarp', but it also failed
> with:
> ---<--------------------cut
> here---------------start------------------->---
> $ /usr/lib/grass64/etc/r.in.wms/r.in.gdalwarp
> in='wms_global_mosaic_nc__0.geotiff,wms_global_mosaic_nc__1.geotiff'
> out=test s_srs='EPSG:4326'
> Creating output file that is 1054P x 1056L.
> Processing input file wms_global_mosaic_nc__0.geotiff.
> 0...10...20...30...40...50...60...70...80...90...100 -
> done.
> ERROR: Projection of dataset does not appear to match
> current location.
> Location PROJ_INFO is:
> name: Albers Equal Area
> datum: wgs84
> towgs84: 0.000,0.000,0.000
> proj: aea
> ellps: wgs84
> a: 6378137.0000000000
> es: 0.0066943800
> f: 298.2572235630
> lat_0: 58.2500000000
> lat_1: 57.0000000000
> lat_2: 59.5000000000
> lon_0: -63.0000000000
> x_0: 0.0000000000
> y_0: 0.0000000000
> Dataset PROJ_INFO is:
> proj: aea
> datum: wgs84
> ellps: wgs84
> lat_1: 57
> lat_2: 59.5
> lat_0: 58.25
> lon_0: -63
> x_0: 0
> y_0: 0
> no_defs: defined
> ERROR: units
> You can use the -o flag to r.in.gdal to override this check and use
> the location definition for the dataset.
> Consider generating a new location from the input dataset using the
> 'location' parameter.
> ERROR: r.in.gdalwarp: r.in.gdal failure.
> here---------------end--------------------->---
if you are confident that projections match you could edit the script
to add the '-o' flag to r.in.gdal.
> ERROR: units
what does 'g.proj -p' say?
Hamish
ps- I have now added a warning to r.in.wms if you try to download more
than 200 tiles at a time.
